Okay my friend says an i7 2600 is bad compared to a fx 6350 what should i get it would be cheaper to get the i7 2600 because my mobo is lga 115 so which one?
Your friend is wrong. The i7 2600 is superior to the 6300 FX. What is your budget? Don't compare Intel to AMD CPUs. That doesn't work. They are different designs.
What is your budget and plan?
my budget is around 190 dollars but the only reason I was going to get the i7 was because my mobo is lga 1155 and it would cheaper than a mobo and cpu change.
