Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
Primal Oooze wrote:
> "Byte" <Byte@discussions.microsoft.com> wrote in message
> news:7B50A0D1-10D1-4913-8D8C-656CBB35F16C@microsoft.com...
>> You probably mean the soundcard. Some manufacturers have updated
>> drivers at their website for old soundcards. If you cannot find one
>> for
> XP,
>> see if they have one for Windows2000 (2K), quite often they will
>> work.
>> Win98 was DOS based and XP is not. Without more info on your
>> soundcard, info assistance will be very limited.
>> XP-WNP
>> Some days you're the windshield.
>> Some days you're the bug.
> The card is a ESS audio drive 1688f.
> I spent a couple more hours searching for drivers (this time with
> corrected card info) and, although there are plenty for all other
> windows op systems, there doesn't seem to be one for xp or 2000.
> Last ditch, there is a function on xp that helps programs designed for
> other os's to work with xp. I can't find it, but have heard about it.
> Any chance that might work?
You are thinking of Compatibility Mode and that is for programs, not
drivers. A PCI sound card can cost as little as $15usd. Just go buy a
new one and install it in place of the ISA card.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
