And why it does not work.
The old monitor is 15 inch and the new one probably has a larger screen.
Meaning your desktop in windows was set to a higher resolution than the 15 inch can display.
Remember the desktop resolution is always stored at a native depending on the monitor.
So with the new monitor connected lower the resolution to 800x 600.
Apply. shut down the pc and connect it to the 15 " and you will get a signal.
If using the 15 pin D sub blue rgb input.
And there you go.
