Old SD card drive doesn't fit in optical drive slot
DanGaEb
Commendable
Mar 1, 2016
17
I took and old SD card reader out of an old PC planning to put it into my computer but it doesn't fit! The dimensions are approximately 10cmx14cmx2.5cm (4x6x1 inches approx).
Is there any way I can get it to fit?
My case is the corsair 200r
Thanks
What country are you??
That sounds like a 3.5inch sd reader, you only have 5.25 inch bays in the 200r.
You can buy a bay adapterbut in all fairness they may cost the same as a new sd reader bay.
