Hi there,
I found an old turntable in my grandpa's house and as I don't know a lot about it and don't understand most manuals I find on the internet, I need some help.
It is a Dual 704 (imgur link below for pictures), I figured out that it doesn't have a build-in pre-amp (I got one, see the pictures, also very old) and that you need to manually calibrate your pitch (after choosing 33rmp or 45rpm, I seem to never get it to stand still at 45rpm tho).
I do not know what the anti-skating does/ how to configure it so any help would be appreciated.
Also under the skating thingy there is a knob with a dot with line under and arrow with dot under, what is that for?
I currently clean my turntable/records with microfiber cloth and liquid for cleaning glasses.
Any things I need to check as the turntable is over 50 years old, and hasn't been used in a very long time.
Pictures:
https://imgur.com/a/n1DKh
Any information and do's and don'ts about this turntables/turntables in general would help!
Thanks in advance!
Pictures:
Thanks in advance!
