Onboard LED's buzzing over audio devices
Kedzie
45
My brand new Biostar TA990FXE motherboard has onboard LED indicators to show different phases of the CPU. One or two of these lights flicker constantly, producing a buzzing noise. This noise can be heard over my speakers and microphone (a person listening to my open mic reports increasing volume of the buzzing the longer the mic is open). I wish to turn off these lights or do something to prevent the buzzing from being transferred onto my audio devices.
See if you can adjust power settings, including Cool&Quiet, to be a little less aggressive with power saving and/or monitoring.
Your board apparently can't make up its mind how much power your CPU needs, and the rapid cycling of power phases is causing your interference.
Edit: And, what PSU (brand and model, not just wattage) do you have? Your board may also be trying to compensate for an unstable power source.
There are many things that can cause 'buzzing' as such, and most of the time the root cause is a cheap or bad PSU.
If you have Utilities like Green Power II Utility installed then Uninstall. Otherwise, I see no way to control anything but the GPU Phases.
This is a LOAD issue, i.e. 9/10 a PSU issue, and as the load changes you're hearing the 'buzzing' noise. I assume the PSU is plugged into a 3-prong GROUNDED outlet; try a different outlet. Sometimes the electricians flip the phases in the sockets.
Otherwise, try the cases' speaker/mic ports or visa versa the MOBO's; verify that you're using the correct Mic port and that the sound control only lists/enables (1) Mic. Next, try the latest Realtek ALC892 drivers - http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false#
Lastly, any sound card or USB Headset is going to be better than onboard sound.
All utilities that came with the Motherboard have been uninstalled (except the motherboard driver, of course). BIOS has been returned to its original settings (after lowering the CPU fan performance AND unplugging the fan altogether), but despite any efforts the problem persists.
This is my power supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371050
Trying a different outlet led nowhere. I do not have any soundcards.
Moving fan to a different header did not work.
BIOS cannot calibrate the fan for some reason. Nonetheless, I put "aggressive" as the CPU fan behavior.
Please keep in mind that the buzzing is present even without the fan altogether.
Noticed this in the manual:
This header allows only HD audio front panel connector; AC’97 connector is not acceptable
What that means on older Case's if the Audio Front Panel isn't HD Audio compliant then it won't work properly and it's best to disconnect the Front Audio to the case.
Through Audio jacks.
Keyboard is plugged into the back jacks, speakers are connected to the keyboard (this keyboard http://www.newegg.com/Product/Product.aspx?Item=N82E16823162014 )
These speakers are connected to the keyboard: http://www.bestbuy.com/site/Logitech+-+Z313+2.1-Channel+Speaker+System+(3-Piece)+-+Black/Silver/9427774.p?id=1218104302605&skuId=9427774
The buzzing is heard over the speakers (which are indirectly connected to back audio jacks through the keyboard)
The other headset, which is connected to the front audio jacks, is http://www.bestbuy.com/site/Dynex%26%23153%3B+-+Earclip+Headset+with+Noise-Canceling+Microphone/8525697.p?id=1186007538719&skuId=8525697
My case isn't old (brand new in fact): http://www.newegg.com/Product/Product.aspx?Item=N82E16811133195
Keep in mind that on my old motherboard I had no audio problems.
Just for the record, this is my PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817371050
Try taking 'the middle man' out of the equation (i.e. keyboard) and use the MOBO's rear audio:
Speakers (Green) ; right center
Mic (Pink) ; right bottom // can also try the Line In (Blue) ; right top
Yeah your older system was AC '97 compliant, this new MOBO is not.
i plugged my smaller headset into the front and back audio jacks, and the back jack has much quieter buzzing (still buzzing, but negligible).
Lemmie switch the AC '97 with the HD Audio and see what happens.
Lazy solution: The speakers' volume needs to be turned up significantly for the buzzing to be detectable. During normal operation, no interference is noticeable. As long as some sound plays through the speakers, the sound will mute the buzzing.
Regardless, when no sound is playing, the buzzing is still irritating (and it shouldn't be present in the first place anyways). But...I got some kind of backup...
Your MOBO doesn't support AC '97 - period.
Reread what I stated, "What that means on older Case's if the Audio Front Panel isn't HD Audio compliant then it won't work properly and it's best to disconnect the Front Audio to the case."
Try disconnecting the Case's audio all together from the MOBO and see what if any affects.
Q - Are you using the latest Audio driver from Realtek that I posted above?
Q - Are you using the latest BIOS?
99FAD229.BST 2012-02-29 - http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=560
Q - In the Device Manager are there any {? or !} devices listed?
Q - Did you use the latest drivers from BIOSTAR? (same link from BIOS above)
In the Device Manager, in Sound... [+] expand and Uninstall everything then reboot.
In the Realtek use the highest sampling rate (DVD); see - http://i1013.photobucket.com/albums/af254/Jaquith/SPDIF-Optical.jpg and then change around the Microphone settings.
I did everything you told me. Nothing changed. One interesting thing though: I tried connecting the HD Audio input into the motherboard from my old case and to my surprise the audio interference was much much lesser (when heard over the audio jack from the old case). How could my new case be providing me clearer interference than my old case?
My old case is http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
