Hello tomshardware users,
it would be very nice to get some tips as I've been struggling with this issue for quite some time now. And I just can't take it anymore. Listening to music is very important to me but these sound problems make it very hard for me to enjoy.
Issue: Popping/cracking noise. This has been an issue for quite some time now. I'm not sure what I did, but for some reason this issue is much reduced from what it used to be, iirc since a few months.
Also: my microphone causes a weird beeping noise that colleagues have told me when chatting over something like TeamSpeak. Plugging into another port or just replugging into the same one usually stops this issue. I could verify the same while recording, which gave me this weird rectangle wave (see https://imgur.com/FZq2kZr).
However, at the same time I always had the feeling something was off with the sound. I'm not sure how I could endure it for this long, or if it's getting worse with time. To describe it in a few words: voices are drowning, the bass is unusually strong and "shaky"/"boomy", classical music / piano pieces sound really bad, the higher vocal range in general lacks richness and strength.
Tried:
Info
Motherboard: ASRock Z170 Extreme4
Graphics card: NVidia GTX 1070
CPU: Intel Core i7 6700K
PSU: 500 Watt be quiet! Straight Power 10
Sound Card: -
OS: Windows 10 x64
Built myself ~2 years ago, was (still is) my first self-built PC and I was completely inexperienced.
Tried:
■ headphones
■ new speakers
■ front and rear audio jack
■ upped PCH voltage
■ UEFI update´
■ used standard UEFI settings
■ Linux
■ reinstalled every driver
■ changed sample rate in Realtek HD Audio-Manager
Info
Sound Card: -
OS: Windows 10 x64
