It's only reading one fan the splitter cable leaves off the other wire on purpose so their only one input. Both fans should truly be running the same speed.Is it normal that one of my fans is not controlled? Couldn't find any information so I'm asking here. The cable splitter for power that came with the cooler had one of the pins missing. One can is spinning at 1300 rpm and the other at 900.
They are the masterfan mf120r RGb.Need more info.
4 wires to fan = PWM, Pulsed voltage speed control with Tachometer feedback.
3 wires to fan = Voltage control of speed
2 wire = on/off full speed
Now what connections does each fan have?
What is the max speed of each fan?
Where does the cable splitter originate?
Keep in mind different fans have different max speeds.
Controling a PWM and Voltage toegether will work but may operate differently, at slow speed 1 fan may not work at fast speed 1 fan may not be fast enough to get rid of the heat.
Oh, I see. That makes sense. Thanks.It's only reading one fan the splitter cable leaves off the other wire on purpose so their only one input. Both fans should truly be running the same speed.
The front panel is sealed. I know it's not ideal, but I still like the case. Just want to know if it would be a better idea to make them pull air in. Also, thought about making the rear exhaust slower rpm, so I can do positive air pressure. I'm still not sure about the pressures and stuff.use the cooler in position same as picture above the front fan pushing air to fin and back fan pulling air out also in you case front should be intake and back with top exhaust you wont have better cooling to put cpu fans on side panel .
