Question Ongoing Connection Issues - Wired/Wireless
It can be any software almost impossible to tell. It is pretty easy to try other drivers. I would get the latest one from the chipset vendors web site. I am going to bet it makes no difference but maybe you get lucky.
It can also be one of the many setting buried deep in windows.
Rather than replace the router try a ping to the router IP from another device. If both have issues then you suspect the router.
