• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
Question Only 1.5mm difference. Will Cooler Master V8 GTS fit??
Tri-Mension
7
I have Cooler Master MB 520 RGB chasis, the Cpu clearance is 165mm
I am dying to buy Cooler Master V8 GTS, the height is 166.5mm.
Now obviously they are not compatible officially, but i wanted to ask has somebody tried such a thing? The difference is 1.5mm.
I have measured the distance from mobo to the inner side of the side panel, and it is 167mm.
Thanks in advance.
Such measurements are not always perfectly accurate.
I suspect that you would be ok.
The side panel is likely a bit flexible, sufficient to allow installation.
That said, buy from a place where you can return the cooler if needed. Expect to pay a restocking fee.
The cooler is certainly a good looking one, likely why you picked it.
There are other coolers that are equally efficient that will fit.
Noctua NH-D15s to name one.
Tri-Mension
7
Thanks for help. Really appreciate it.
The only option I have is Ali Express, and the seller has agreed to take a picture of the cooler with a ruler measuring the exact height. It will be a risk, but sadly due to lockdown situation this cooler is out of stock in my country.
Yes initially I started researching Noctua NH-D15s, but really its the esthetics of V8 that changed my mind.
