okay, so basically i bought a motherboard which supports all the way up to 7.1 surround sound.
But the ting is: it only does that by using one 3.5mm jack. View: https://imgur.com/gallery/2qVg1Ke
But my 5.1 speaker configuration needs 6 total RCA cables. View: https://imgur.com/gallery/FWhBnt5
I only got 3 times 3.5mm jack to one red and one white RCA in the package.
as you can see in this video
View: https://youtu.be/_ounn-NFYM0
is that he plugs it into extra 3.5mm ports that i do not have.
so basically i am missing 2 ports. any advice?
I am also now running this in stereo mode and that works fine but i just kinda want it working in true 5.1.
I thought of a male 3.5mm jack to 3 female 3.5mm jacks audio splitter. but I do not know if this will work or maybe even buying a soundcard to go into my pc.
If one of y'all know if this may fix this or have another solution please leave a comment.
thanks in advance.
thanks in advance.
