Question Opinions on replacing dying R9 295x2 with GeForce RTX 3050 or Radeon RX 6500 XT?
minun
152
I removed my R9 295x2 from my computer because it was causing shut downs under load, currently using a temporary GPU, hoping it is not permanently damaged, I am planning to re-paste it and hope it will manage its core temperature, the reason why I think it is damaged is because prior to the shut downs, it struggled to play Halo Infinite on the lowest settings with the smallest resolutions, even though it should be able to
Preparing for the worst, I am in the market for a replacement GPU, even second hand and I saw that both AMD & Nvidia are retailing their new entry cards very soon
The GeForce RTX 3050 and Radeon RX 6500 XT, while the GeForce RTX 3050 is more appealing to me, on techpowerup.com it says that the Radeon RX 6500 XT is comparable to the R9 295x2?
View: https://imgur.com/a/BNUSudW
What sucks is that these cards are not x16, my PCIe Bus is 2.0.
Looking to gather some insight before I commit to any of these
Windows 10 Pro Version 21H1 (OS Build 19043.1348)
Motherboard: GIGABYTE GA-X58A-UD7
CPU: Intel BX80613i7980X Core i7 980X Extreme Edition
R.A.M.: Patriot Gamer Series 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
PSU: Corsair HX1200i 1200W
