Hello everyone!
After finalizing my build with the help on another thread, I started researching PSUs again.
This is, when I noticed, that the T1 Corsair RM650x and T2 Seasonic Focus Plus Gold 650 are in incredible close range to the TX650M recommended to me in the other thread, so I'm kind of set on going with either of those - if I fancy it one day, I can even go full cable mods with those (20% off, due to Strix Mainboard).
Now the question is:
Is the 5-10€ premium over a TX650M worth it?
And is the Focus Plus or Corsair Unit better, as they're both rated very high from Jonnyguru.
My specs btw:
i5 8600K
Strix z390-E
Strix 1080 A8G
500 GB (860 EVO)
500/1TB HDD (not sure here)
16GB G.Skill Tridenz Z RGB 3200 (CL16)
4 Fans (2x140 Front, 1x120 Back, 1x 120 Dark Rock 4)
Some Graphics Cards oc is optional, will opt for 4,5-4,6 on the CPU, that's why I went with 650w.
Main purpose will be for Gaming, some University stuff from time to time, nothing more than writing Protocolls & doing some research.
And, as both are Semi-fanless, Seasonic however can be turned off, is there any problem regarding heats? I read a thread, where they didn't recommend fanless due to additional heat towards other components, if the case is small enough. Shouldn't be a problem with a Phanteks Enthoo Pro M Tempered Glass?
Tl;dr:
Corsair RX650m vs Seasonic Focus Plus Gold 650 vs TX650M
My specs btw:
i5 8600K
Strix z390-E
Strix 1080 A8G
500 GB (860 EVO)
Tl;dr:
