[SOLVED] Orange Dram Light On help!
Computerneedhelp
I just got a new computer and have installed everything but when I went to boot it gave me an orange Dram Light. I used these ram sticks in another pc before this one so I know that they work, I tried removing them and putting them in different slots and using 1 at a time and still no luck. I removed my gpu made sure it was in tight and double checked the cpu installation. The only other thing that I think it could be is I'm using cable extensions and they could be faulty. Any other suggestions or things to try out ?
Asus prime x570 pro Ryzen 5 5600 gtx 1070ti 650watt EVGA gold 2 nvmes crucial ballistix 3200 16gb ram
Yellow light is usually a RAM incompatibility issue. Use 1 stick. 3000 series to 5k is a big jump. It may not like it. Yep, update the bios. Have some different RAM to try just in case.
Sep 5, 2021
24
