[SOLVED] out-of-band management network card for desktops ?
Cantercrow
Hi,
I am looking to see if you can get an out-of-band management network card for desktops.
I have not found much yet but would like a solution similar to iLO or iDrac for a remote desktop I use for testing so I can access and change the OS etc.
Does anyone know or a reasonably prices solution?
Thanks
Julian
Does the desktop you are trying to remote manage have Intel vPro or are you using and AMD Ryzen Pro chip? Those might have something similar to OOB management. Otherwise I do not know of any NIC you can buy that will allow such operations. At that point if it is required you will have to get a motherboard that comes with OOB installed on it right away.
