over clocking G3258 with H97M pro4 *HELP NEEDED* *ASAP*
macelodeon
103
So I have been meaning to over clocking my G3258 for the full experience. So I have been exploring of places, and have come to that the H97M can not over clock unless it is the anniversary edition, but I have read that I can over clock the G3258 on almost any motherboard including this one. So I will post some pictures of the UEFI layout, if needed, so can someone tell me step by step how to over clock the G3258 with the current UEFI? I tried to follow all of the video tutorials, but I have not been successful. I have tried to use the A-tuner software from ASrock, but it does not work for some reason, on one side of the "page" it states "software is not supported" or something like that. but under that it states "Works with pentium anniversary" which I have (G3258 anniversary), in the end it did not work out, neither can I find any english tutorials on the internet that tells me how to use the program. If someone knows whats up can you do a full procedural writing on what I need to do to over clock? huge thanks 😀
photos of UEFI:
http://imgur.com/uIflm3i
http://imgur.com/3Tc0ro2
http://imgur.com/dQAREOl
http://imgur.com/LfiqjzV
http://imgur.com/7gxZJPE
~maceFTL
Ive hear d that I also need to change the volt multiplier?
set the voltage to ~1.2 and then set it to adaptive mode, you might not even have to mess with voltage if you're stable at around 4.3-4.4ghz
OK, I will go into my UEFI and take some pictures, I need you to tell me what I need to change, this would mean the world.
Sure thing!
I just put imgur links in the main post.
Under the OC tweaker scroll to the top and you sould see some kind of cpu clock speed multiplier, change that from 3200 to around 4400 if you can
Hm, i read around online that you need to do a bios update before you can overclock
Do you know what version I need/where I can get it? (link)
i read this http://www.tomshardware.com/forum/id-2755375/overclocking-g3258-asrock-h97m-itx.html
but to get the bios update then go to asrock.com and search your mobo until you find downloads then get the update
There should be a bios update,
and besides that,All MSI motherboards support Overclocking,even the cheapest ones.
I could overclock on my old H61-P23-B3 without problems,and i bought it for 15$
all I need to update is Intel SBA?? there seems to be nothing else to update? (and microsoft framework)
The links i provided are from the same link,
Download Version 2.00 Windows,
And if that doesn't fix it try version 1.20 Windows
So I have version 1.20 but when I click it everything runs, asks to restart, what ever, but nothing happens when I restart?
Because it finished installing the bios,try overclocking.
Like I said before, no changes to the bios, none, looks just like the pictures I posted.
I finally was able to force update the UEFI while in it... yeah fun. SO I FINALLY acheived The over clock to 4.2 ghz, heres a pic of when I was stress Testing the CPU for around 10m, should I do this for a longer period of time? also I just selected the option for a 4.2 Ghz and did not adjust the voltage at all, it automatically selected 1.279 V, is that fair?
(pic): http://imgur.com/A8ZHZK3
yep, thats a reasonable voltage for that speed
few thats great, im going to play some games and see if there was a performance boost :)
Go for it, you should see a nice bump in performance, if you have any other questions just shoot me a pm and id love to help ya out
