Hey people,
I have a problem, I decided i should make an account here to get some help.
I was in the bios, trying to push it further and changed the bclk frequency to 140 from 100.
I changed everything to the same settings that had been running smooth; so for my CPU it's at 4.5g and the memory 1866 (with the changed bclk frq) but it broke...
The symptoms are: restarting randomly once logged in, settings not applying in bios, it froze but i could still use the mouse just extremely slow (mem?).
The bios seems buggy, some settings don't change, and they appear twice in the save screen etc so my gut feeling is it's the MB?
Don't have specifics atm, would appreciate it if you could tell me what to do so i can find the problem and solve it seeing as I wouldn't want to damage it further.
I ran some memtests and it is showing errors, one test showed 3 the other over 2k.
Specs:
Proc - Intel 4820k
Fan - Noctua NH-D14 SE 2011
Ram - G.Skill Sniper F3-1866C9D-16GSR
PSU - Corsair Builder Series CXM 750W
MB - Asus Sabertooth X79 Motherboard Socket 2011
SSD - HyperX 120GB SATA3 3K
HDD - WD 1TB 3.5 Caviar Blue
GPU - Asus GTX 770
SC - Creative OEM PCI-E Sound Blaster Z
Feel free to ask questions, and thanks in advance for any help
Specs:
Proc - Intel 4820k
GPU - Asus GTX 770
