Overclocked cpu Liquid cooler?
nick546
35
I have a i7 4770k OCd to 4.5ghz.My nh d14 died and i am planning to go watercooled.I want one that will keep my temps at full load at around ~60.i keep my pc running for about 12 hrs a day.
The heat sink itself cannot die unless you drill a hole in the heat pipes, fans can die Yes, and be replaced with better higher performance fans than the ones that came on the cooler in the first place! :pfff:
http://www.performance-pcs.com/cata..._info&cPath=36_1130_49_1043&products_id=28613
or
http://www.performance-pcs.com/cata..._info&cPath=36_1130_49_1048&products_id=24570
or these 110cfm bad boys
http://www.performance-pcs.com/cata..._info&cPath=36_1130_49_1047&products_id=24517
or
