[SOLVED] Overclockers system vs Pc specialist
kevinburrow
Commendable
Mar 17, 2020
156
33
1,790
So i've put these 2 together. My budget is £850, so there's a whole lot of room for improvement, particularly in the Overclockers build. It seems much better value to me so far:
Overclockers (£734):
  • Kolink Bastion Mid Tower
  • ASUS B450 Plus Gaming
  • AMD Ryzen 5 2600
  • Corsair Vengeance LPX (2x8gb) DDR4 3000
  • Gigabyte Radeon RX 590
  • WD Blue M.2 2280 1TB
  • Raijintek Themis CPU Cooler
  • Seasonic Focus 550w 80+Gold Modular
Pc Specialist (£812):
PCS P209 RGB MID TOWER CASE
AMD Ryzen 5 3600 Six Core CPU (3.6GHz-4.2GHz/36MB CACHE/AM4)
ASUS® PRIME B450-PLUS (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
8GB AMD RADEON™ RX 580 - HDMI, DP - DX® 12
1TB ADATA SX6000 Pro PCIe M.2 2280 (2100 MB/R, 1500 MB/W)
CORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
  • AMD Ryzen 5 2600
1TB ADATA SX6000 Pro PCIe...
  • AMD Ryzen 5 2600
Hi @kevinburrow
While OC'ing is & can be nice, I would hands down buy the 3600 system over the 2600 if those were my only choices. The 2600 is a nice CPU in its own right, but the 3600 is just much better. Couple that with the faster RAM and you'll have a beast. The 580 you have with the 3600 is slightly slower than the 590, but unless you could get a deal, not worth swapping the 2.
Whats the PC's main function gonna be? Gaming? Productivity?
Either way, you'll be happy, just happ(ier) with the 3600 system 😀
Reactions: kevinburrow
Hi @kevinburrow
Thanks, I could easily upgrade to the 3600 on the Overclockers and it would come in cheaper still by a fair bit. The only issue I have is that is the fastest 16gb Ram they have available for some reason. I was disappointed by that. I wanted the 3200 set at least.
Overall I use it for a mixture of browsing and gaming but the only reason I don't game as much now is because I don't really like gaming unless i can crank the graphics up to decent levels, which is hard now with my crusty 1050TI ^^. So at the moment I generally stick to games such as Civ 6 and Football Manager, but I'll def be on AAA titles when I have a system worthy of it.
I did look at the comparisons and RX 590 was pretty much equal with the 1660 , and a bit cheaper https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1660-vs-AMD-RX-590/4038vs4033
I could definitely upgrade to the super, but as an average gamer am I going to notice that much difference for a fair bit more money?
Edit, having looked it possibly would be worth it but it's about £50 more and about 10%-15% better. About what I'd expect, but within my budget. Thankfully, I have a lot of wiggle room so that's definitely a good upgrade as far as I can tell. I could even bump the processor to a 3600 with no issues.
Reactions: King_V
Well, part of the equation worth considering, in addition to average frames, is what the minimum frame rate is in each game with the different cards, which gives you a very approximate idea of how often it might dip below a desirable minimum. A side note, but one worth considering.
Added bonus is that you're talking a far lower power draw - TDP rating of about 125 for the 1660 Super, versus the 225 for the RX 590. The power bill may not be affected as dramatically as that difference makes it sound, but less total heat output from the GPU means less heat in the case to worry about, thus less work for your cooling system overall.
Looking on Ukgamingcomputers now and I think they're even better. Never heard of them tbh but they have great ratings.
Case - Game Max
GPU - NVIDIA GTX 1660 Super
M/B - ASUS Tuf B450 Gaming
Processor - Ryzen 5 3600
RAM - Corsair Vengeance 2400mhz FREE UPGRADE TO 3000mhz
Storage - 500gb Samsung 970 Evo Plus M.2 NVME SSD
PSU - Corsair CX 550
£744 icl. VAT and delivery
I still have £100 odd to play with, and could upgrade to a GTX 2060 for another £80. Then again the case and PSU are pretty cheap, and I don't know anything about the case really. At least the PSU is Corsair, even if it's their bargain one. I'd also like to have at least 3200mhz RAM to make use of the Ryzen but I don't want to pass up on that free upgrade :/
Wait, the listing I'm seeing is showing RTX 2060 . . I'm not sure what you mean about "upgrading" to a GTX (?) 2060 for £80 more.
I don't know much about cases myself, so can't say much about it, but yeah, I'd definitely want a Seasonic Focus or a Corsair TX, TXm, RM, or RMx instead of the CX.
I would say, though, that you're unlikely to see much difference in gaming performance between 3000MHz and 3200MHz RAM. Maybe a few fps, if that.
