Hi all,
I have an ASRock AB350M motherboard with a Ryzen 1800X. With it, I have some Neo Forza 2400MHz CL17 RAM (2x 8GB). The product code is NMUD480E82-2400EA10 but searching gives me little more than an Amazon page showing out of stock and the Neo Forza website which simply lists it as a product.
I would like to find out if it's possible to make my system perform better during gaming by overclocking my RAM (my CPU is already at what I believe is a stable 3.9GHz). I couldn't find any XMP settings option in BIOS (ASRock UEFI 5.7, latest version) so I had to try my best to find what settings I'd use manually.
Using Thaiphoon Burner, I found the manufacturer (Hynix), memory type (part number ended in 1FR so I tried "Hynix MFR" and "Hynix AFR" as options) plugged it into DRAM Calculator for Ryzen by 1usmus (1.4.0), input the DRAM Voltage and timings as suggested for a "Safe" setting. However, nothing I've tried so far will work, and I did notice the Frequency is set at 2666 MT/s minimum, with my RAM rated at 2400. I wonder if this implies there's not much I can do with my memory? Currently at 2400MHz, 15/15/15/36 with 55 tRC.
Any advice would be appreciated!
