Overclocking advice/check for Phenom II x4 955 BE, Ripjaws 1333mhz, EVGA 550TI
stringplay
12
Can someone check my overclock settings and provide some advice.
I condensed what overclock settings others received from similar hardware along with using what OC GENIE gave as a reference and applied it. Still new to the overclock.
Also how should I adjust the CPU NB & HT Link in tandem with the CPU clock? How should I adjust their respective voltages? What's the difference between CPU NB voltage and NB voltage? How should I adjust HT Link voltages? How should I adjust SB Voltage?
Hardware:
Hyper +212
CPUz:
CPUz-Memory:
GPUz:
Overclocked the GPU:
GPUclock :1000mhz
Memoryclock :2096mhz
I vary voltage between 1110mV to 1113mV(I've seen artifacts at 1110 but havent tested 1113mV)
Benchmark:
Furmark 3 hours : 55Cmax
Overclocked the CPU/Ram:
Base Clock : 200(untouched)
CPU FSB Frequency: 3800
CPU NB : 2400
FSB/DRAM ratio : 1:4(1600mHz)
Ram Timings : Auto
HT Link Frequency : 2200
CPU Voltage : 1.431
CPU NB Voltage : 1.158
DRAM Voltage : 1.662
SB Voltage : Auto
NB Voltage : Auto
HT Link Voltage : Auto
Benchmark:
prime95 3 hours :62C(however delta fan must be at 4000rpm)
Planned Operation:
World of Tanks
BF4
BF3
Neverwinter
Shogun II
LFD2
League of Legends
Photoshop
Adobe Premiere
autoCAD
Minesweeper
