Hello all. I am new to overclocking and need some advice.
I own an Intel DX48BT2 motherboard with 2 x 2GB of Kingston DDR3 PC11000 HyperX 1375 RAM. I'm considering buying either the Intel Core 2 Duo E8600 3.16GHz or the Intel Core 2 Quad Q9550 2.83GHz CPU.
I would like the Q9650, but at $230 more than the Q9550 for only 0.17GHz, it seems to me like a waste of money. After researching between the Q9550 or E8600, I think the Q9550 is the way to go for "future-proofing" my system.
My question is this, the Q9550 uses a multiplier of 8.5. If I wanted to overclock the Q9550 to 3.2GHz, is it a simple case of raising the FSB to 376, making 376 x 8.5 = 3196? If I do that, is the RAM affected at all? Is anything else required to be adjusted?
For this I'll be running with the stock Intel cooler, mainly because I'm put off the size and weight of after market coolers. I do have a copper Intel cooler as well as an aluminum one, I'll likely use the copper one with some AS5.
Thanks for any advice you can provide.
