Overclocking difference
Wonderwill
558
I am planning on getting a computer with an E6600. I know I could buy a cooler and OC it, but I don't know if it would make too much of a difference if all i'm doing is video editing. I would also have to choose a different motherboard. Isn't it already fast enough for me without the hassle?
rushfan
268
Video editing benefits from faster components, the CPU included. Even a modest overclock will help and you may not need esoteric cooling for a small bump in clockspeed (~200 MHz).
Many basic motherboards support changing the Front Side Bus speed. Raising it 20 - 25 MHz might do the trick without having to change any other setting in the BIOS, CPU voltage included.
wolfman140
297
The C2D's are too easily overclockable to not take advantage of it. I've OC'ed mine to 3.0Ghz with very little effort or voltage increase (although I can't go higher cuz my temp gets too high). 2.13ghz to 3.0Ghz (or more) is a HUGE increase. That kind of increase of Ghz would cost a fortune (like the E6800) to buy without OC'ing...I can't see a reason why you WOULDN'T want to OC. Even if it was a modest one to 2.66Ghz or so. You should be able to get a decent OC on stock cooler anyway.
1Tanker
Splendid
Apr 28, 2006
4,645
All the posters are correct, but to answer your last question, a stock-clocked E6600 will work great for encoding/editing. But, in order to get the most out of it, an enthusiast motherboard (975x/P965 chipset)is recommended(which most have very good O/Cing abilities). GL :)
