Overclocking from 1600Mhz to 1866Mhz
AMKANMBA
153
Hi, I just made my first build. I have an i7-3770K on an asrock z75 pro3 along with 2x4GB G-skill ripjaws X (1600MHz) . In my BIOS there is an option to set my RAM's frequency to various speeds. Would it really be as simple as that? will it be safe to OC my ram to 1866Mhz or even 2133Mhz? What softwares can i use to find my ram's stability before and after OC? and finally what are the factors which are of my concern during OC.
you can do memtests as you try to oc your RAM also you might want to add voltage because when you increase the frequency you'll need more power
i have never oc'd my ram before so i might not be the best person to ask just giving a little "intro" i guess :)
I have GSKILLS RIPJAWS, PC3 12800 1600Mhz 2x4gb set in a single channel on my ASROCK 990fx Extreme 9. How do I overclock to 1866Mhz? Any help would be greatly appreciated.
I have the same question,
with these Avexir AVD3U16001008G-2CIG DDR3-1600 16GB (2x8GB) Green LED
* Manufacturers part code: AVD3U16000904G-2CIG.
* System platform type: Desktop.
* Memory type & speed: DDR3-1600 (PC3-12800).
* Capacity: 16Gb (2x 8Gb).
* CAS latency: 10-10-10-24.
* Test voltage: 1.5v.
* Registered or Unbuffered: Unbuffered.
* Error checking: Non-ECC.
Can i OC it to 1866? my mobo is msi a68hm-e33 v2 and using a8-5600k.
