Overclocking FX-8350 @4.5Ghz Temps
Yep that's why 32C ambient is hot. So it wouldn't be a bad idea to check the temps once in a while but you should be fine.
Really!?... The huge spike at the beginning worried me a bit, then it dropped after a few minutes. I am here in the Philippines and its 32c at the moment. Also, it's pretty dusty here since my apartment is by the main road. Thanks!
