Question Overclocking T9550 to it's nature speed or more
Jan 4, 2022
6
Hi,recently I BSEL mod the T9550 to make it runs in my GM965 motherboard.The speed,because underclock to 800MHZ from 1066MHZ physically (as the computer refuse to boot),reduce the clock speed from 2.66GHZ to 2GHZ only.Can anyone here teach me how to overclock it back to 2.66GHZ or even 3GHZ?Thanks.
If it is locked too (like mine) then no luck 🙁 (although you cant raise a value you can decrease it,
Note!!! : While using throttle stop click the "TURN ON" button at the bottom before changing the values :):)
That's bad,my CPU can't be overclock using throttlestop as using throttlestop only lets the CPU always running at 2GHZ only.I would need to find for other solutions
