overclocking with stock cooler
tinydez
53
so ive recently received my 8320 and i was wondering if i could overclock to 4.0-4.2ghz without voltage change on stock cooler. i will eventually get after market hsf but cant afford it right now.
Processor will work harder overclocked, so even if you don't change the voltage (which would probably cause stability issues) it will generate more heat. If you want to try it just make sure to have a CPU temp monitor open!
