Overclocking Woes with ASRock P67 Extreme4 Gen3 and Core i7-2600K
AppleBlowsDonkeyBalls
117
I finished my new rig four days ago, and I've installed most everything I need to get it running. I'm now wanting to overclock, but it has proven largely fruitless. The max I'm able to get out of it is either 3.8 or 3.9GHz. I've seen getting to 4.5GHz in most cases requires a more significant voltage increase, so I've decided to set my limit at 4.4GHz. I don't think temps. are the issue; I'm running it with a Corsair A50 and even with the insignificant 3.8GHz OC it doesn't go higher than 55-56C in Prime95.
Here's what I've set up in the UEFI:
OC Tweaker:
Load Optimized CPU OC Setting: Default
CPU Control:
CPU Ratio Setting: Manual
Max Ratio: 44
Internal PLL Overvoltage: Enabled
Intel SpeedStep Technology: Enabled
Intel Turbo Boost Power Limit: Auto
Additional Turbo Voltage: Auto
Core Current Limit: 200
BCLK: 100.1MHz
Spread Spectrum: Auto
DRAM Configuration:
<I don't think what I've set here has anything to do with it, so I won't include all the info. I'm running 8GB (2x4GB) Kingston HyperX Genesis at 1600MHz with 9-9-9-24 timings at 1.59-1.60V.>
Voltage Control:
Power Saving Mode: Enabled
CPU Core Voltage: Offset Mode
Offset Voltage: -0.005V
CPU V-Core: 1.32V
CPU Load-Line Calibration: Level 3
DRAM Voltage: 1.59V
PCM Voltage: 1.059V
CPU PLL Voltage: 1.704V
VTT Voltage: 0.986V
VCCSA Voltage: 0.925V
CPU Configuration:
Intel Hyper-Threading Technology: Enabled
Active Processor Cores: All
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
Enhanced Halt State (C1E): Enabled
CPU C3 State Support: Enabled
CPU C6 State Support: Enabled
Package C State Support: Auto
CPU Thermal Throttling: Enabled
Intel Virtualization Technology: Enabled
No-Execute Memory Protection: Disabled
What could've gone wrong? I already tried disabling C1E and Power Saving Mode, and I also disabled Spread Spectrum and it didn't do anything. :??:
This is an old thread now, but I tried this and it worked. Even after disabling Power Saving Mode EIST still works, too, so that's good.
I got it stable to 4.3GHz at 1.27V.
Thanks a lot for the help. :)
