Overdrive problems 64 bit
LostintheWoods
Hello, I am running Windows 7 on my computer and have downloaded overdrive and the updates. When I try to download an audio book to my computer, It still gives me this error message: The version of this file is not compatible with the version of windows you are running. Check your computer system information to see whether you need x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publishe
I am having the same problem. Every time I try to download an OverDrive WMA Audiobook (146200 kb) I receive a message saying
"the program or feature"\??\C:\\Windows\Installer|{D4A.......exe" cannot start or run due to incompatibility with 64-bit versions of Windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available."
But the program is already supposed to be 64 bit compatible so I don't know what to do.
