Cooling capacity??? That's for the actual cooler to deal with. The purpose of paste is a bridge, to aid in heat energy transfer from one surface to another. Said bridge just needs to have a proper connection, i.e., good coverage in those pits its filling. That's it, that's its job. What it does for operating thermals is minute and perhaps a little icing on the cupcake compared to one's cooler selection, which has far greater impact.
Let's just agree to disagree, please?
Yeah, thermal pads should be the absolute last resort, 'cause it's so easy to go down a rabbit hole on that one.
-Some find out the thickness of the original pads, and pick based on that, but it isn't the only factor.
-Pads have a certain degree of hardness; soft, medium, firm, etc.
-There isn't a universal test condition for pads, so the advertised numbers need to be taken with some salt. For example, the temperature at which one set of pads starts to flex or mold is different from another brand's.
By the way, what is the gpu hot spot looking like? [Use Gpu-Z or hwinfo to see it.]
I'd like to ask about memory junction too, but it couldn't be seen on many 20 series cards via software - EVGA's FTWs were some of the only ones that did it.
