Are you trying to run the game higher than the card can handle, i.e. ultra or high settings? 80-82C for the gtx 650i boost is way too high. How are your fans setup in your case, good airflow, cooling management? Does your cards fan work and it is at 100% all the time? That idle temp is a little high at 40C, too. What software are you using to measure the temps?
