P4 Overclocking Guide
scottchen
Splendid
Jun 3, 2003
5,791
<A HREF="http://www.geocities.com/antireligionclub3/" target="_new">P4 Overclocking Guide</A>
Update: You probably noticed that in my guide there aren't any instructions on how to overclock the new LGA775 chips, they're all the same principal, push vcore up slightly, go bit by bit, like 5FSB. I will be writing a new extensive guide on what hardware is needed and how to overclock the Socket775 chips, once the Presler and Cedar Mill core CPU's are released.<P ID="edit"><FONT SIZE=-1><EM>Edited by scottchen on 07/25/05 05:39 PM.</EM></FONT></P>
До каких частот можно разогнать Pentium D 820? И на сколько это выгодно (по производительности)? Up to what frequencies it is possible to disperse Pentium D 820? And on how many it is favourable (on productivity)?
Ты вообще понял что написал? если да, то переводи сам, потому что на кривых языках я не разговариваю! You in general have understood that have written? If yes, translate itself because in curve languages I do not talk!
Как мне свой 5800 баллов в 3D Mark 2005 увеличить до 6500? Память гнать бесполезно. Мой компьютер: Intel Pentium D 820, MSI 945P neo2 F, 2*512 Kingston pc-5300, nVidia 7600 GT. How to me the 5800 points in 3D Mark 2005 to increase up to 6500? Memory to drive it is useless. My computer: Intel Pentium D 820, MSI 945P neo2 F, 2*512 Kingston pc-5300, nVidia 7600 GT.
Nobody understands you matey. You need to check your post and try and send it in english, in some kind of sentenced, understandable structre!
Either that or try and find a russian overclock forum?
Good luck in your attemps anyway :)
Forums to search to me for laziness, and that he is well overclocked I know, simply wished to know up to what limits. And here the "Project 5Gh " has come having recollected a roller .
The link is dead. Does anyone know if this guide is hosted somewhere else or where I can find a similar guide to show me how to overclock my P4 3.0E?
I have a P4 3.2 6XX H/T 800 FSB.... P5ND2 SLI MOBO.... mushkin ddr2 533 mhz 4-4-4-12... Ultra xfinity 500 watt psu... Ultra cpu cooler 3.2-3.8
current setting:
clock:
core speed-- 3920.2 mhz
mutiplier-- X16
buss speed-- 245 mhz
rated fsb-- 950 mhz
memory timing: original setting 4-5-5-13 dual channel
NOW:
frequency-- 245 mhz
fsb:dram-- 1:1
cas# latency-- 2.0 clocks
ras# to cas# delay--3 clocks
ras# precharge-- 3 clocks
cycle time (tras)-- 5 clocks
bank cycle time (trc)-- 9 clocks
With this new settings it do not hang up. I tried burning movies using nero7 ulra edition. Also running at the same time, avira anti virus (scanning), Azureus and U-torrent downloading at the same time.... With all this running do not hang-up... with this load temp. is 36c to 42c.... with no load its 24c... mobo stays on 36 all the time
thanks for all you hard work on the guides.
I just ordered an asus board and I have a pentium d 945.
Hopefully all will go well.
Im certain you will here from me when its all together.
Im going to try to compare what you wrote to what i have before I ask any questions
My P4 3.2 GHz HT runs smoothly and cool up to 3.6 GHz.
At 3.8 it crashed with little load.
Using stock cooler.
All the OC has been done with the Asus tool.
I am wondering if replacing the stock Intel cooler for a Zalman CNPS9500 LED would improve anything...
I have a Pentium 4 3.2 w/ht overclocked to 4 ghz@1.41v on thermalright air cooler
2x1 gig of mushkin ddr2 533mhz 4-4-4-12 2T @1.85v running on 500mhz 3-3-3-9 1T@1.85v
2x1 gig of G.skill ddr2 533mhz 4-4-4-12 2T @1.85v running on 500mhz 3-3-3-9 1T@1.85v
on a p5nd2 - sli mobo
have s478 p4 3.0 ghz @ 3.7 on air with zalman flower cooler, Relax memory to 333 in bios, ramp volts to 1.415 on cpu and tickle fsb up to 247mhz, fsb then effectively 988 mhz and clock at 3705 mhz. memory nearly back up to 400mhz
have pushed to 3.9ghz but needed window above pc open to super cool room to middle winter in midlands temp to keep stable on air lol
^Oh yeah? I have a Celeron 315 2.66 OCed to 3.6+Ghz.
http://valid.x86-secret.com/show_oc.php?id=272070
