P4C800-Problem with Gigabit LAN :(
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi!
I have a strange problem here.
I use the P4C800 deluxe with a 2,8 GHz Prescott and Infinion RAM, not
overclocked.
Whenever i use a Gigabit Connection to the OnboardBoard LAN it will not
post. No bios, no beeps, nothing at all.
Afzter disconnecting the LAN it will still not post, i have to switch the
power supply of, make a reset and then - after connecting it again with
power and switching on it will post and i get the message that i have
overclocked too much and i can enter the bios.
When i use a 100 MBit connection all works fine.
The same Gigabit connection works fine of 2 other PC's.
Any ideas?
Best regards
Axel
Sounds really weird. Is the mobo mounted correctly? Has a screw dropped
between the mobo and case? Are mounting posts only in the correct positions?
- Tim
"Axel Gillert" <axolotl@blackoctagon.com> wrote in message
news:c9p7c6$k32$00$1@news.t-online.com...
> Hi!
> overclocked.
> Any ideas?
> Best regards
> Axel
Yes, all done. And, funnywise, when i plug the Gigabit cable in the MoBo
after WinXP has already startet it works fine with a 1GB connection...until
the next reboot...
"Tim" <Tim@NoSpam.com> schrieb im Newsbeitrag
news:c9pf6j$1bu$1@lust.ihug.co.nz...
positions?
> - Tim
> > Hi!
> > overclocked.
the
> > Any ideas?
> > Best regards
> > Axel
