Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
"Paul" <nospam@needed.com> wrote in message
news:nospam-2211042149110001@192.168.1.177...
> In article <gNSdnTHB6dfsSzzcRVn-vQ@fcc.net>, "Jeff" <jeff@aol.com> wrote:
> > THANK YOU PAUl.
> > Just two other things, does this cancel the mic input on the back Panel?
> > Also. if I remove the jumper caps on the pinouts on teh MB and onnect
the
> > headphone wires from the front panel to them, can i then have a
situation
> > where connecting a headphone would then "kill" the sound coming from the
> > speakers connected to line out from the back plate?
> > TIA
> > jeff
> Your mixer control panel for the sound system, should offer
> a MIC1 and a MIC2 setting. MIC2 would be the microphone connected
> to the FP_AUDIO header.
> Front panel headphones are a little more complicated.
> If the headphone jack on the front of the computer has
> three wires, it is an ordinary non-interrupting style
> jack. If you remove the two jumper caps, and connect the
> three wires, you lose use of Lineout on the back of the
> computer.
> If you can find a way to do the same job as the two jumpers
> (i.e. keep shorting those two pairs of pins, like the jumper
> caps would), and connect the three wires to their intended
> connections, you could have front panel audio and Lineout
> at the same. There would be no interruption, but you'll get
> a burst of noise or a "pop" from the speakers when plugging
> or unplugging.
> If the computer case has five wires for the headphones, then
> the wiring supports the "interrupting" option. When the five
> wires are connected, plugging in headphones on the front,
> cuts off speakers on the back (Lineout). Again, if you can
> find a way to do the same job as the jumper caps (i.e. short
> the pairs of pins the way the jumper caps would), then there
> won't be an interrupting function, both outputs work at
> the same time, and you might get clicks and pops when plugging
> in.
> To make a cable that is both a jumper plug and a contact
> for wiring to the front panel (making a non-interrupting
> headphone setup):
http://frontx.com/order_c.html (the page I found these...)
http://frontx.com/cpx075_8.html (jumper plugs - buy 2)
http://frontx.com/cpx076.html (enough for 5 jumpers in one pkg)
http://frontx.com/cpx076_2.html (male contact - one pkg enough)
> Make two of these cable assemblies. One for left and one for
> right channel headphone. The 075_8 end fits onto FP_AUDIO,
> and the 076_2 connects to the headphone wiring on the front
> of the case.
> Plastic Female Male
> Body Pins Pin
> 075_8 076 076_2
> X | XXXXX---|
> X | XXXXX---|-----------------xxxxx
> +--- Crimp two wires into this pin, so all
> three pins are shorted together. I.e
> / like this.
> V
> X X x
> X X x
> X X x
> X X x
> X X x
> The body of the male pin will need to be covered with black
> electrical tape, as Frontx doesn't seem to sell the plastic
> cover for the single male pin. The two female pins, after the
> wires have been crimped in place, slide into the 075_8 two
> position jumper body, and will click when the little tab on
> each pin is in place. If, where the wire is crimped, is too
> fat, the pin will not fit properly into the plastic body.
> Since you have extra pins, you'll need to experiment a bit,
> to get it right.
> You also need a little wire. The jumper plugs I have sitting
> in front of me, specify #22 to #28 gauge stranded wire, as
> fitting into the crimp pins. Radio Shack 278-1224 is pretty
> close to being the right kind of wire - as the number goes up,
> the wire gets smaller, so #22 is the largest diameter and
> #28 is the smallest. With the #22 gauge, you might have a
> little trouble fitting two wires into one of the female
> pin bodies. Maybe two #26 gauge wires would fit. If you
> take a sample of the female pin to Radio Shack, maybe they
> can suggest a wire likely to fit the pin. Or, if you have
> a real electronics parts store in your town, they may be
> able to supply all the parts needed themselves. I have only
> one store in my city that can handle such an order.
> HTH,
> Paul
Paul,
I also havd a 3.5 inch unit combo Multi memory card with headphone jack and
mic jack, with a moled ten pin jack with one jack mising, will do this do
the job to making the front panel accessible the way in which you speak the
way as front x does?
Also, the mixing program which shows mic 1 and mic 2, is that in sound
properies control panel (windows mixer?)
TIA,
jeff
