p4p800-e deluxe, hdd led always on
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have built a system around the P4P800-E Deluxe, and put it in a Kingwin
K11 case. Just one small problem, the HDD activity led is permanently on.
Just one hard drive - a Western Digital SATA plugged into the SATA1 slot on
the motherboard, and the master on the primary IDE is a DVD-ROM drive. There
doesn't appear to be a separate place to plug in the HDD led if you're using
a SATA drive. I am missing something here or is this something that may just
need a BIOS update?
On Fri, 7 May 2004 07:50:10 -0700, "Frankie Howerd"
>need a BIOS update?
I'm using the rockethead adapter and mine stays on as well...
i thought it was the adapter but aparently not !!
ñíñjà¤têç
---END---PGP---SIGNATURE---
"ñíñjà¤têç" <bs@aol.com> wrote in message
news:egg0b0lktr40midjd9uu9rrm84bvm04t69@4ax.com...
on
There
using
just
> >need a BIOS update?
> ñíñjà¤têç
What BIOS are you using??, I have 2X SATA 80GB Both as Primaries, 2X 120GB
both as Primaries on the Via Raid channels and optical drives (both as
Primaries) on the standard IDE connectors and no problems with the HDD light
regards
Fredddie
On Mon, 24 May 2004 01:26:47 +0700, "Freddie Clark"
we are using "IDE" drives with an adapter to connect them to the sata
controler...
ñíñjà¤têç
news:aeg5b0l2a798lsob86807e298dm44m5tie@4ax.com...
> controler...
> ñíñjà¤têç
Don't feel bad, running 3 drives here, 2 on Primary IDE and 1 on Sata
Ide port and I got no HDD light. Bet I have it on backwards but it's such
a pain to get to I haven't fixed yet ;-)
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! >100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Try turning the hdd light around on the pins on the motherboard.
Glen
"tk" <tk@home.com> wrote in message news:40b4b556$1_1@127.0.0.1...
> > controler...
> > ñíñjà¤têç
News==----
Newsgroups
"Glen" <meetfreeaddress@hotmail.com> wrote in message
news:40bc8f18_1@mk-nntp-2.news.uk.tiscali.com...
> Glen
I just had to go back in and make some changes and reversed mine and
all is good now.
>> > controler...
>> > ñíñjà¤têç
> News==----
> Newsgroups
>> Encryption
"tk" <tk@home.com> wrote in message news:40c3d697$1_1@127.0.0.1...
> > Glen
> all is good now.
BAH if I try reversing on the pins the led doesn't work at all. Oh well, a
minor problem I suppose.
"Frankie Howerd" <frankiehowerd@yahoo.com> wrote in message
news:10cd7kcqnbtsfe8@corp.supernews.com...
>> > Glen
>> all is good now.
I've seen this before on other systems I've worked on, wish I knew what
the cause was. Do you think the HDD's arrangment on the IDE cable could
be wrong? (master/slave).
"tk" <tk@home.com> wrote in message news:40c8a21f_1@127.0.0.1...
> >> > Glen
> >> all is good now.
a
It's a SATA drive plugged into the SATA1 port on the mobo. The master on the
IDE cable is a DVD-ROM drive.
news:10cieb3rghgoo5d@corp.supernews.com...
>> >> > Glen
>> >> all is good now.
>> > well,
> a
> the
Haven't had the pleasure of owning a SATA drive yet hope more info comes up
here cause
Asus website is about useless I think.
