G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
P4P800 E Deluxe
P4 2.8e (Prescott)
Omni 400w OR Yaha 350w
1 x 512mb Kingmax pc3200
Auriga Radeon 9200 OR Gigabyte GeForce 5200
Liteon DVD ROM
Liteon DVD RW
Windows 98 SE
Hello again all
This is an old problem but i ahve been too caught up with other things to
worry about a PC!
When i first built this system the problems it was having were random
re-boots random system hangs and acting if there were minimal ram while
ripping/burning
The re-boots seem to have been solved by setting the RAM manually as advised
by Kingmax website.
Now there was suggestion that a bios flash may help as i have a prescott CPU
HOWEVER
i can not even run a full extended test suite with extended memory map with
MS memory tester even once before the system will hang or cause an
'exception' - so im goin nowhere near a flash.
The instances are not always on the same test
This is with nothing but the CPU, ram, vid card, floppy, monitor, kb, mouse
and speakers plugged in.
I cant run memtest86 at all - it just loads for a short time flashes blue
and re-starts - the usb legacy change makes no difference.
I have tried different sticks of ram, alternate vid cards and alternate
power supplys all with the same problem
The temps sit quite nicley at 30ish for the MB and 45ish for CPU
The only noteable difference is when running the 350w power the 3.3 voltage
bounces around 3.07 - it is higher with the 400w
SO
I know its not the ram, PSU, vid card or OS leaving me with Motherboard or
CPU .. not a nice prospect
PLEASE PLEASE PLEASE i need some more of the advice that has been fantastic
to eliminate .. now its time to locate !!
TIA
JAZ
P4P800 E Deluxe
P4 2.8e (Prescott)
Liteon DVD ROM
Liteon DVD RW
Windows 98 SE
Hello again all
worry about a PC!
ripping/burning
by Kingmax website.
HOWEVER
SO
TIA
JAZ
