p4p800-mx fan noise....
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hello NG guru's,
The fans in my system start full speed and keep doing so all the time
(cpu-case and powersupply) resulting in a little to much noise.
Anyone know a solution for this???
Grtnxx Stegmann
Stegmann wrote:
> Hello NG guru's,
For an idea of what is available, try www.quietpc.com. The Zalman
coolers are very good. There are alternatives - I bought a nexus quiet
power supply from www.novatech.com which has helped a lot
Chris
cut along the dotted line to reply
"Stegmann" <nosp@mfor.me> wrote in message
news:qlxx56e9514t.1sk78yefjx8ev.dlg@40tude.net...
> Hello NG guru's,
> Grtnxx Stegmann
I leave the side panel off on my K8V, otherwise the fan makes too much
noise. It's just poor ventilation in the case - cheap case. Of course better
ventilation means more fans so leaving the side off is a good compromise.
> Hello NG guru's,
> Grtnxx Stegmann
How much do you want to spend?
Try an aftermarket fan, but with more powerful CPUs, fan noise this is
pretty much par for the course these days.
If you have your PC case on the top of the desk try putting it under the
desk.
