Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Op Wed, 17 Nov 2004 12:22:45 -0400 werd er meegedeeld door Paul:
> In article <dv227ksp395h.skfcvedctzp8.dlg@40tude.net>, Stegmann
> <nosp@mfor.me> wrote:
> > Op Tue, 16 Nov 2004 19:15:26 -0400 werd er meegedeeld door Paul:
> > > In article <11rjkm12gzr1a.1ou5v3kmmajuz.dlg@40tude.net>, Stegmann
> > > > Hello NG,
> > > > I've build a system with the asus p4p800-mx board , but cannot get
the
> > sound
> > > > going.
> > > > XP Pro SP2.
> > > > Yellow questionmarks for multimedia-audiocontroller in
> > > > hardware-devicemanager.
> > > > Tried to reinstall , doesn't work. , error :
> > > > AppName: soundmax.part1.exe AppVer: 0.0.0.0 ModName: user32.dll
> > > > ModVer: 5.1.2600.2180 Offset: 00015bc3.
> > > > Supplied support cd cannot be explored , autorun doesn't work. , so
> > forget
> > > > the support in 'support cd'.
> > > > Please help it's very quiet now.............................
> > > 1) Your CD drive may be having trouble reading the disk.
> > > Either find another CD drive to read the disk, or
> > > attempt to clone the CD, using a burner. If you have
> > > a CDRW, it may have better luck reading the motherboard
> > > CD than your current drive.
> > > The autorun on the CD does a check of what chipset is on
> > > the motherboard. The CD contains support for multiple
> > > motherboards, and the autorun has to figure out which
> > > files to offer. (If the disk was readable, you could
> > > also Explore it.)
> > > There have been reports from other users, of problems trying
> > > to read the Asus motherboard CD. I had some trouble with mine
> > > when using a very old CDROM drive.
> > > 2) Assuming you cannot read the motherboard CD, download the
> > > files from Asus. The first file is 7MB, and the other three
> > > total 35MB.
ftp://ftp.asus.com.tw/pub/ASUS/mb/sock478/p4p800-mx/inf.zip
ftp://ftp.asus.com.tw/pub/ASUS/mb/sock478/p4p800-mx/SoundMAX_part1.zip
ftp://ftp.asus.com.tw/pub/ASUS/mb/sock478/p4p800-mx/SoundMAX_part2.zip
ftp://ftp.asus.com.tw/pub/ASUS/mb/sock478/p4p800-mx/SoundMAX_part3.zip
> > > For the second group of file, you will need to unzip and
> > > decompress them, before the installer is ready to be used.
> > > By installing the chipset drivers first, that will allow the
> > > facilities in the chipset to be enumerated properly. Then,
> > > using the Soundmax installer should go smoothly.
> > > HTH,
> > > Paul
> > Thanx Paul,
> > The first link you offer i havn't tried , but the following three i did
> > exactly like it should , but when executing the first file i also get an
> > error message about the file being corrupt.
> > I will try to instaal the first and proceed with the 3 others.
> > My cd-rom is actually a brand new dvd +/- double layer burner.
> > I'll let you know how things work out..............
> Yup, reads corrupted for me as well...
> These are the MD5SUM for each download file
> 3a8fc7239118cb50f26d0677c77fb235 SoundMAX_part1.zip 12556940 bytes
> 9d3d0d49f7137c860c354a068b285adc SoundMAX_part2.zip 12564977 bytes
> 216bfa9e8eaf55176da0671441889c35 SoundMAX_part3.zip 10830385 bytes
> After the unzip of each individual file above:
> 184006c8a44a44c6a41c3a80f6dbc9e8 SoundMAX.part1.exe 12582912 bytes
> 7618d410913e9b55ef192d5e4e53b7d3 SoundMAX.part2.rar 12582912 bytes
> 8a014d0cc9e6ba8f45ac7c8a606cd089 SoundMAX.part3.rar 10834485 bytes
> But executing the .exe finds the files corrupted.
> Try this one. This should be for the same AD1888/ICH5 combination.
> This is from the P4P800S download page. I think the P4P800S-X is
> the same.
http://www.asus.com.tw/support/download/selectftp.aspx?l1_id=1&l2_id=15&l3_id=25&m_id=1&f_name=AD1888.zip~zaqwedc
> At least this one unzips OK. Give this a try.
http://www.asus.com/pub/ASUS/mb/sock478/P4P800S-X/AD1888.zip
> Good luck,
> Paul
Hello,
I have stopped trying and called the store to complain about this problem
and they said that often the 'support' cd's from asus cannot be read , and
this could easily be solved by copying the cd and use the copy to install
drivers...................................................
I did it and it worked..................
Thanks for the provided help.
Grtnxx Stegmann
