P5AD2 Premium STANDBY problem
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
ok... Thank you very much Paul...
I'll give it a try and post back the results...
Just to antecipate... I've already performed more than 10 new ( clean )
Windows installations... but the problem was still the same !!! It seems
the OS is not recognizing the motherboard ACPI management feature (
don't have a clue why... ) ... On all of those installation processes
I tried ( in each time ) BIOS default parameters, POWER MENU Suspend
Mode [S1 (pos) only], POWER MENU Suspend Mode [S3 only], POWER MENU
ACPI 2.0 Support [Yes], POWER MENU ACPI 2.0 Support [No], etc.
... anyway...
Juts to let you know... At this very moment, I have the following
"dumppo" power capabilities information:
power capabilities
System power capabilties
Power Button Present....: TRUE
Sleep Button Present....: FALSE
Lid Present.............: FALSE
System states supported.: S5
Hiber file reserved.....: FALSE
Thermal control.........: FALSE
CPU Throttle control....: FALSE
Processor min throttle..: 100
Processor trottle scale.: 100 (1%)
Some disk will spindown.: TRUE
System batteries present: FALSE
System batteries scale..: (G:0 C:0) (G:0 C:0) (G:0 C:0)
Ac on line wake ability.: Unspecified
Lid wake ability........: Unspecified
RTC wake ability........: S4 - hibernate
Min device wake.........: Unspecified
Default low latency wake: Unspecified
...ok... Now I'll go through the suggested steps and hope to achieve
the "so wanted" result.
Thanks again...
Geferson
Geferson Kowalsky
In article <Geferson.Kowalsky.1l1jvn@news.computerbanter.com>, Geferson
> ( clean )Windows installations... but the problem was still the
> same !!! It seemsthe OS is not recognizing the motherboard ACPI
> management feature (don't have a clue why... ) ... On all of
> those installation processesI tried ( in each time ) BIOS
> default parameters, POWER MENU SuspendMode [S1 (pos) only],
> POWER MENU Suspend Mode [S3 only], POWER MENUACPI 2.0 Support
> .. anyway...
> following"dumppo" power capabilities information:
> power capabilities
> achievethe "so wanted" result.
> Thanks again...
> Geferson-- Geferson Kowalsky
Yes, your results seem to suggest ACPI is not there. Have
you checked the Device Manager and looked at the properties
of "Computer" ? Is it "Standard PC" or is the word "ACPI" in
the title ?
If the word ACPI is present in the Device Manager, I would
try this next. What I'm trying to do here, is get the
"System states supported" to change to S3,S4,S5.
dumppo admin /ac minsleep=S3
I just found this posting, and maybe the info here will help.
More info on using dumppo.exe. It seems "dumppo admin" as
a status check, is a useful option.
http://forums.pcper.com/showthread.php?threadid=190313&perpage=15&pagenumber=3
HTH,
Paul
