p5ad2e premium and problem raid4 sil 3114
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
i have xp sp2
1 disk for system "c:"
3 disk for raid5 (sil3114) " x:"
I have used for raid5: latest driver asus and software for create raid5
SILSAM00014C.EXE
PROBLEM:
1) when copy files disk x: (raid5) il very slow (6000kb/sec)
2) if install raid managment utility java for monitoring disk, smart,
send email ecc ecc= system crash when software starting
if removo driver raid5 and install satalink drivers for raid0 and raid1=
managment utility working and system not crash
if installa raid5 drivers end lounch managment utility system blue
screen.
as I make to use drivers raid5 and monitoring disk? (smart, send email,
ecc)
In article <hpuvh1hruqnml7gq05pg3vd5satlslbc9j@4ax.com>,
supermazzinga@yahoo.it wrote:
> i have xp sp2
> SILSAM00014C.EXE
> PROBLEM:
> screen.
> ecc)
I don't see any hardware XOR (exclusive OR) function in
the silicon. This is a dumb controller:
http://www.siliconimage.com/docs/SiI3114_PB_090103.pdf
Perhaps you could try WinXP built-in RAID5. Tomshardware
has a recipe for it:
http://www.tomshardware.com/storage/20041119/raid5-01.html
This will probably not go any faster, but the RAID Management
might be bug-free. You should be able to place the drives
on any available hardware controller that supports single
disks.
The problem with buying real hardware RAID5 controller cards,
is the cards are likely PCI-X and may not fit in your PCI
card slot. If you could find one of these cards, or ones
similar to these, you would be limited by the PCI bus
bandwidth. Real RAID5 costs money. (2cpu.com and
forums.storagereview.net are good private forums
with information on setting up RAID arrays.)
http://www.2cpu.com/forums/showthread.php?t=57853
1820A fits in a PCI slot, and you might get 100MB/sec via
a 32 bit PCI slot if you are lucky. ($220 USD). When the
controller chip on a card has a heatsink installed, chances
are it has hardware XOR for RAID5 built-in, so your processor
doesn't have to do the calculation.
http://www.highpoint-tech.com/USA/sataraid.htm
http://www.highpoint-tech.com/manuals/RR1820A%20V1.2_UM.pdf
Have fun,
Paul
I am understood the limits of the controller integrated in p5ad2-e
but I do not understand the reason for which "raid utility java for
monitoring harddisk" crash con driver raid5 and work with driver raid
0/1
other motherboard not asus with 3114 raid5 supply software for control
end monitoring of harddisk.........
I have used the program of the motherboard INTEL and work with the
driver raid5 asus.....but this program more is limited of raid utility
java 1.0.14 or 1.0.19
>> i have xp sp2
>> SILSAM00014C.EXE
>> PROBLEM:
>> screen.
>> ecc)
>disks.
>Have fun,
> Paul
In article <nap081d4a55avlv2cq7ctjb4t8dru3dcg0@4ax.com>,
> 0/1
Have you tried the "Sataraid tools" download from the Silicon Image
web page ? Uninstall the current version first, then try this one.
http://www.siliconimage.com/products/product.aspx?id=28 -->
http://www.siliconimage.com/docs/SiI3114-Sata%20RAID%20Management%20Utility.zip
Paul
> >> i have xp sp2
> >> SILSAM00014C.EXE
> >> PROBLEM:
> >> screen.
> >> ecc)
> >disks.
> >Have fun,
> > Paul
this is versione 1.0.13
i have test 1.0.13 - 1.0.14 - 1.0.19
the problems is equal....system crash when start utility whit driver
raid5
system not crash when start utility whit driver raid 0/1
i'm test in other system and other mb asus and problem persist
>> 0/1
> Paul
>> >> i have xp sp2
>> >> SILSAM00014C.EXE
>> >> PROBLEM:
>> >> screen.
>> >> ecc)
>> >disks.
>> >Have fun,
>> > Paul
supermazzinga <supermazzinga@yahoo.it> writes:
> SILSAM00014C.EXE
> PROBLEM:
> screen.
> ecc)
Loading the raid5 drivers BSOD'd winxpsp2 for me, too. Then it
wouldn't boot. Writes are slower than reads for raid5, anyway, so I
just punted and configured raid10 with my four drives. I get raid0
performance with raid1 protection. Worked for me!
Forte International, P.O. Box 1412, Ridgecrest, CA 93556-1412
Ronald Cole <ronald@forte-intl.com> Phone: (760) 499-9142
President, CEO Fax: (760) 499-9152
My GPG fingerprint: C3AF 4BE9 BEA6 F1C2 B084 4A88 8851 E6C8 69E3 B00B
i use 3 disk of 300gb
3x300 to raid5= 600gb online
if use raid1 o also raidx i not 600gb and not security for date
On Tue, 24 May 2005 17:59:49 -0700, Ronald Cole <ronald@forte-intl.com>
>> SILSAM00014C.EXE
>> PROBLEM:
>> screen.
>> ecc)
if buy 4th disk for raid1 o raid10 cost= 200euro
promise controller raid5 = 200e
>> SILSAM00014C.EXE
>> PROBLEM:
>> screen.
>> ecc)
