If the DRAM light is on during boot, reseat your memory modules if you haven't already since you might have dislodged them when you bumped other things. As stated before, check to see if you have any bent CPU pins. Unless you were to take off the chipset heatsink to somehow check to see if you broke the bga solder balls on the chip, I wouldn't even consider taking a heat-gun to the board.
It's also possible you installed the wifi card wrong. I have this motherboard and I remember during installation that I had to take the motherboard back out because I forgot to screw the wifi card in before placing the board in the case. If you just put it in without removing the motherboard, you might have placed it into the pins incorrectly. If you didn't read the manual, you could have missed the step that has you remove the screw on the bottom of the card next to the connector that you then use to screw in through the motherboard from the bottom. That screw might be causing a short if it's touching something on the motherboard.
Wireless Module Installation
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1155/P8Z77-V_PRO/E7198_P8Z77-V_PRO.pdf#page=63
