P8z77 WS Wake On LAN Not Working
ahemsa
45
I have recently built a new computer based on the ASUS p8z77 WS motherboard which has two Intel 82574L NIC's installed.
I am running Win 7 x64. For a NIC driver I have 12.7.27.0 dated 5/16/13 from Intel's website. I THINK this is the latest but I wouldn't swear to it though, their driver website is abysmal. In the device manager, power management, wake on lan, I have selected "Wake on Magic Packet" and "Wake on Magic Packet from power off state" on both NICs. "Wake on pattern match" is NOT checked.
I am running the latest BIOS, version 3505. In the BIOS I have DISABLED eRP and ENABLED allow wake up from PCI/PCIe devices.
When I tell Windows to shut down it shuts down cleanly and powers off. I have verified that BOTH NICs have link lights. I can send a magic packet from either my Android app or another computer and it does absolutely nothing. I have two other computers on the network which wake on lan perfectly so I know that the packets are being sent properly from my WOL apps.
I have tried each individually with no success.
Ideas?
The Intel website would lead you to believe that is a newer driver, but it is not. On the website it lists it as 8/29/13, however, when extracted and installed the device manager shows 5/16/13 as the date. Thinking that it might have just not installed the latest driver, I manually extracted the files from Intel and compared the dates on the DLL files, which are indeed, 5/16.
Any other guesses?
My laptop, with a broadcom wired NIC, has the options you mention under the power management tab. The intel, on the other hand replaces those options with these options.
It has the following:
Power Saver Options:
Reduce link speed during standby (have tried checked and unchecked, no difference)
Reduce link speed during battery operation (haven't messed with this because it's a desktop)
Reduce link speed to save power (have tried checked and unchecked, no difference)
Wake on LAN:
Wake on Magic Packet (currently checked)
Wake on Pattern Match (currently unchecked)
Wake on Magic Packet from power off state (currently checked)
Wake on Link Settings (currently unchecked)
