Question Packet burst in COD Vanguard and unstable packet loss in Halo ?
Dec 1, 2021
25
Hello, im about to give up trying to solve my problem. So I am having this stutter problem in Call of Duty vanguard where it pops up with packet burst. The same thing in Halo Infinite pops up "unstable Packet loss". I have Gigabit internet, with a new modem (even tried using my 5g hotspot on my phone and still got the packet burst sign). My latency is low, when i have the packet loss counter on it shows zero. I have done everything software wise under the sun. Fresh windows install and bios updates. I have gone as far as switching out motherboard and cpu from amd to intel. I have borrowed my friends gtx 1070 graphics card and it still does it. I have an nvme and i got a second ssd and loaded games on that. I have tried almost everything everything. Only two things i havent done is pulled out my 4 8gb of ram and changed the psu.
Here are my specs
EVGA rtx 3060
MSI Z590 Pro wifi motherboard - previous was a b550 aorus pro
I7 11700K - previous was ryzen 5 3600xt
Cooler Master 750 watt PSU
Seagate 520 500gb nvme
SK Hynix 500gb SSD
4 sticks 8gb ddr4 corsair vengeance pro ram
cooler master water cooler
Coolermaster is the brand, while 750W is the advertised wattage. please state the model of the unit. How old is the PSU in your build? Same story for the cooler you're working with. What OS version are you on at the time of writing? Can you also mention the source of your OS installer? You seemed to have migrated from an AMD Ryzen platform to an Intel platform, which BIOS version are you currently on for your Intel motherboard?
Make and model of your router? Check to see if it's got any firmware updates pending.
Thanks! The psu is Cooler Master MPY-7501-AFAAG-US MWE 750 Gold Full Modular, 80+ Gold Certified 750W. PSU is less than a year old when I started the whole build. The build sat for awhile until I could find a graphics card for a reasonable price.
I am running windows 10 and source was I bought a Microsoft key from Best Buy that came with the usb flash drive.
when I can get to my computer I’ll check the bios. I haven’t touched the bios for intel so it might just be the original.
Router is the Netgear Orbi RBR20. Doesn’t seem to have any firmware updates.
You need to do a bit more to see if you have a real network issue or it is something with the pc.
If you have a second device can you leave a ping run to say 8.8.8.8 while the game runs. You are trying to see if both devices have issues at the same time. This would be more likely to be some kind of network issue.
You can also open a CMD window and leave a constant ping run in the background. In this case you want to ping your router IP and something like 8.8.8.8. You are trying to see if the internet goes down or if it is inside your house being the pc or the router.
Ok I will try that but would that really be the issue if I’m am using an Ethernet connection? Also I have pretty much changed out every part on my PC.
It is not likely the ethernet. In fact I doubt it is a actual network issue at all but before you go crazy digging around your machine for stuff you need to verify it really is just your machine that is being affected. In effect you are trying to prove that the game is telling lies when it says it has packet loss.
I don't trust any modern Netgear firmware. They used to be a good company, but I think maybe some of their better programmers left and the new people aren't as good. Their firmware has gone downhill in the last few years.
In fact, people with your same router are having the same exact issue, even hardwired to ethernet, check reddit: View: https://www.reddit.com/r/orbi/comments/ful1wc/orbi_rbr20_packet_lossinconsistent/
I would try a different router, even an older one if you have it laying around, or can borrow one from a friend temporarily.
Here is my stats after playing a round in cod and i had the packet burst sign pop up multiple times.
Packets: Sent = 539, Received = 539, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 60ms, Maximum = 247ms, Average = 67ms
the 247ms hit before i loaded the game.
Any suggestions on a good router to buy? Something that won't break the bank but can handle up to 7 to 9 devices running at the same time.
0 Packet loss is good, but this latency looks really bad, what were you pinging? 60ms min and 67ms average look normal, but that maximum of 247ms looks really bad?
Try holding a constant ping to another device in the house while playing a round. Find out the ip of another computer or device and ping it constantly. If it spikes there, then you know the problem is internal to the router. If it's only over the internet, you may have a problem with your ISP, the modem or the router's WAN.
As for routers, before you spend any money, I would verify it's the cause of the problem. The easiest way to do this is to borrow an old router from someone who may have one lying around. If you don't have that, then probably buy one on Amazon, make sure it's sold by amazon so it's easily returnable.
I prefer Asus routers that allow you to run Merlin. Any of the routers on this list should be fine: https://www.asuswrt-merlin.net/
I was stupid and used yahoo first for the test this is the test from google
Ping statistics for 8.8.8.8:
Packets: Sent = 311, Received = 311, Lost = 0 (0% loss),
Minimum = 19ms, Maximum = 50ms, Average = 25ms
I wanted to post my results of this new test. I didn't even run the game just let the ping test run for a bit and i notice ever so often it spikes. I bolded and underlined all of the spikes to make it easier to read.
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=26ms TTL=118
Reply from 8.8.8.8: bytes=32 time=36ms TTL=118
Reply from 8.8.8.8: bytes=32 time=71ms TTL=118
Reply from 8.8.8.8: bytes=32 time=22ms TTL=118
Reply from 8.8.8.8: bytes=32 time=34ms TTL=118
Reply from 8.8.8.8: bytes=32 time=28ms TTL=118
Reply from 8.8.8.8: bytes=32 time=25ms TTL=118
Reply from 8.8.8.8: bytes=32 time=23ms TTL=118
Reply from 8.8.8.8: bytes=32 time=29ms TTL=118
Reply from 8.8.8.8: bytes=32 time=24ms TTL=118
Reply from 8.8.8.8: bytes=32 time=21ms TTL=118
Reply from 8.8.8.8: bytes=32 time=42ms TTL=118
Reply from 8.8.8.8: bytes=32 time=31ms TTL=118
Reply from 8.8.8.8: bytes=32 time=35ms TTL=118
Reply from 8.8.8.8: bytes=32 time=27ms TTL=118
Reply from 8.8.8.8: bytes=32 time=38ms TTL=118
Reply from 8.8.8.8: bytes=32 time=33ms TTL=118
Reply from 8.8.8.8: bytes=32 time=20ms TTL=118
Reply from 8.8.8.8: bytes=32 time=30ms TTL=118
Reply from 8.8.8.8: bytes=32 time=37ms TTL=118
Reply from 8.8.8.8: bytes=32 time=32ms TTL=118
Reply from 8.8.8.8: bytes=32 time=47ms TTL=118
Reply from 8.8.8.8: bytes=32 time=58ms TTL=118
Reply from 8.8.8.8: bytes=32 time=49ms TTL=118
Reply from 8.8.8.8: bytes=32 time=41ms TTL=118
Reply from 8.8.8.8: bytes=32 time=142ms TTL=118
Reply from 8.8.8.8: bytes=32 time=62ms TTL=118
Reply from 8.8.8.8: bytes=32 time=43ms TTL=118
Reply from 8.8.8.8: bytes=32 time=56ms TTL=118
Reply from 8.8.8.8: bytes=32 time=45ms TTL=118
Reply from 8.8.8.8: bytes=32 time=17ms TTL=118
Reply from 8.8.8.8: bytes=32 time=89ms TTL=118
Reply from 8.8.8.8: bytes=32 time=88ms TTL=118
Reply from 8.8.8.8: bytes=32 time=230ms TTL=118
Reply from 8.8.8.8: bytes=32 time=90ms TTL=118
Reply from 8.8.8.8: bytes=32 time=195ms TTL=118
Reply from 8.8.8.8: bytes=32 time=75ms TTL=118
Reply from 8.8.8.8: bytes=32 time=61ms TTL=118
Reply from 8.8.8.8: bytes=32 time=82ms TTL=118
Reply from 8.8.8.8: bytes=32 time=40ms TTL=118
Reply from 8.8.8.8: bytes=32 time=109ms TTL=118
Reply from 8.8.8.8: bytes=32 time=171ms TTL=118
Reply from 8.8.8.8: bytes=32 time=92ms TTL=118
Reply from 8.8.8.8: bytes=32 time=57ms TTL=118
Reply from 8.8.8.8: bytes=32 time=115ms TTL=118
Reply from 8.8.8.8: bytes=32 time=48ms TTL=118
Reply from 8.8.8.8: bytes=32 time=67ms TTL=118
Packets: Sent = 358, Received = 358, Lost = 0 (0% loss),
Minimum = 17ms, Maximum = 230ms, Average = 30ms
Try pinging your cell phone or something inside the house on the same network. You can find your ip address easily on your cell phone or another PC. Even an old xbox or something you can find the ip address easily. Then ping that IP address instead of google.
To try and rule out the router I just directly connected my modem to the computer and this was my results
Packets: Sent = 549, Received = 549, Lost = 0 (0% loss),
Minimum = 18ms, Maximum = 124ms, Average = 25ms
