I must run Win XP 32-bit due to legacy applications. I have a new mobo with 16 GB of RAM which allows PAE. Boot drive is ssd, also have a Sata III hard drive (d
. Using Superspeed, I created a Ramdisk using the unmanaged part of RAM (above the system RAM), it works like a charm. On boot, z: is partitioned, NTFS formatted and \temp is created. Browser cache files are set to z:\temp, no problems. There is zero impact on my system memory. The problem is I can't move the pagefile to the Ramdisk. I set it up, and it says it's on z: (including the registry), but when I look with Windows Explorer, the pagefile is on c: not z:. I can move the pagefile to d: no problem, but not z: Any ideas on how to get it on z:. I also disabled crash dumping as I heard that could be the problem (it wasn't).
