paging file problem
ezrider
i get this error message when win2000 loads, just after
the logon screen: "Your system has no paging file or the file is too small."
this message is followed by instruction on how to solve
this problem and then an "OK" button.
problem is, the system never loads after i confirm the
message (pressing "ok") i just get the same message again.
(the only thing that loads is the welcome sound)
same thing happens in safe mode too.
how can i fix this proble?
thanx.
note: the system was infected by viruses and i've ran
win2000 repair from the setup utility. (after removing all
the infected files of course) after that i started getting the error message.
<A HREF="http://support.microsoft.com/default.aspx?scid=KB;EN-US;q249321&" target="_new">http://support.microsoft.com/default.aspx?scid=KB;EN-US;q249321&</A>
<A HREF="http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q140472&" target="_new">http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q140472&</A>
I'm sorry, but this is what I could come up with. Unfortunately, you might just have to go with a clean install. [sad] I guess you'll just have to ask yourself, "Is the time waiting for a solution better than just running a clean install?" Unless........Toey!?! :lol:
Bryan
_________________________________________________
<b><A HREF="http://www.btvillarin.com/phpBB/viewtopic.php?t=329" target="_new"><font color=red>My system rig</font color=red></A></b>
<b><A HREF="http://forums.btvillarin.com/" target="_new"><font color=green>btvillarin.com forums</font color=green></A>
<A HREF="http://www.btvillarin.com/" target="_new"><font color=green>btvillarin.com</font color=green></A><font color=green> - Windows XP stuff and more</font color=green>
<A HREF="http://fullservicepromotion.btvillarin.com" target="_new"><font color=green>btvillarin.com Full Service Website Promotion</font color=green></A><font color=green> - Promote and optimize your website for quality hits</font color=green></b>
This might help, too:
<A HREF="http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q259151&" target="_new">Paging File Functionality Requires System Account Permissions and Proper Size</A>
It's also possible that the paging file is corrupt, which means you might have to remove it so it can be recreated:
<A HREF="http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q255205&LN=EN-US&SD=gn&FR=0&qry=pagefile.sys&rnk=12&src=DHCS_MSPSS_gn_SRCH&SPR=WIN2000" target="_new">How to Delete the Pagefile.sys File in Recovery Console</A>
<A HREF="http://www.wown.info/j_helmig/wxprcons.htm" target="_new">Windows 2000 / XP Recovery Console</A>
Be sure to check your settings and allow Windows to control the paging file placement and size in this situation.
Toey
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
<A HREF="http://www.btvillarin.com/phpBB/index.php" target="_new"><b><font color=purple>BTVILLARIN.com</font color=purple></b></A> - <i><font color=orange>A better place to be</font color=orange></i>. :wink:
not necessary... what do u have ntfs? if that the case, u migth check the permision in the local disk some times u change that security by mistake and when u reset the pc can't read the page sisyem file.
try that...
mishkka
try this...
check the local permissions for in the security tab u probably cahnge that in the local hard drive, that could be the more important reason to do not allow u to read in the page file.... read this... "Your system has no paging file or the file is too small." u see "too small" that means that u don't have access to the page file system not necessary that the page file is corrupt, try that i let us know.
