Palit GTX 1060 to my old VGA monitor?
jrdn128
35
my main problem is i cant find out what type of DVI my GPU has so i cant decide which adapter to buy. since i dont enough budget yet to buy new monitor. here is the spec from palit website
main-qimg-3f076ad67fc83b85e249483340f18e85
i need help selecting cable adapter to buy
which of those choices will have a better impact for performance?
thanks. ill use adapter at the mean time. till i can afford new Monitor. is there gonna be a huge improvement if i buy a new model monitor? in terms of performance
depends on what you buy. dvi-d can carry a better resolution than vga for sure. hdmi and display port are even better. if you're gonna buy new, then an hdmi or display port is what you are looking for. dvi is also getting to be old tech and should be slowly dying as well. some newer cards have even dropped this output and only have hdmi/dp ones.
a cheap adapter for now until you buy a new monitor is good enough for the moment
i found this item for sale in my country hdmi to vga active gold plateshould work?
