Yes, I think that power supply would be fine.
About the memory. Did you check the spec's on the memory and try setting the spec's up the same in your bios? If it does'nt work you can always reset the bios back to its defaults.
Reply to other people: Yes dimm 1 and 3 or dimm 2 and 4 should be populated on this paticular motherboard to get dual channel mode. But just because the board won't post using dimm 2 and 4 does not mean its a bad motherboard. Especially if the memory is non-standard ( 1.8v), and non-standard timings, which he has not listed exactly what it is yet. I have seen this many times on non-standard memory, ( will post with one stick and not two). Sometimes a bios update fix's this also, but the board being a new model, I doubt if they have an update yet.
About the QVL lists. Manufactures only test a few model's and brands, so other memory will work also. There is only a hand full of major memory manufactures out there, and all the memory companys buy from them. They re-program the memory, put there logo on it, put there heat spreader on it, and sell it under there own name.
