I've been working on this pc for a while now, slowly getting parts as time and money allowed. Most of the import parts (CPU, GPU, etc) have already been purchased; however, before I open anything up, I'd like to get some feed back. The primary purpose of this build is 4k gaming, but I may do things like 3D printing and modeling later down the line. I also realize I may have gone too far in a few places, but I'll justify my decisions below. Any advice and/or criticism is appreciated.
PCPartPicker Part List: https://pcpartpicker.com/list/fpqYBc
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard
Memory: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3600 CL18 Memory
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive
Storage: Samsung 980 Pro 1 TB M.2-2280 NVME Solid State Drive
Video Card: MSI GeForce RTX 3080 10 GB GAMING X TRIO Video Card
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case
Power Supply: SeaSonic FOCUS Plus Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Case Fan: Noctua A15 HS-PWM chromax.black.swap 82.52 CFM 140 mm Fan
Case Fan: Noctua S12A PWM chromax.black.swap 63.27 CFM 120 mm Fan
So the CPU and cooler are slight overkill for gaming. I wanted the 5600x for mild workstation loads, but I didn't want to spend the money on a 5800x. I'm using an aio just to try out water cooling, having never done so before. It's a 360 because it'll probably look better in the case compared to a 280. The aio will be top mounted, exhaust, pull config (since Arctic Freezer in push won't fit in my case, according to a user on pcpartpicker).
Mobo is an x570 for future proofing, since I may change parts 5-6 years from now. VRMs seems to be decent based on reviews. A B550 could have done the same job, but this was one of the cheaper x570 boards, so I don't feel like I went overboard with this. Asus board used so I can control its rgb via iCue, which is a thing apparently. (btw using iCue to control RAM and maybe light strips as well)
Memory is 32GB because my monkey brain likes high numbers. Also, some R programs I've run have used more than 16GB. (These programs are dealing with remote sensing, if anyone is interested).
Primary 1TB Storage is M.2 PCIE Gen 4 for fast boot speed. 500GB secondary for extra storage. Less cable management using 2 M.2s instead of a 2.5''.
GPU was the only 3080 available to me. Fortunately, I was able to pick one up at Microcenter a few months ago. Since the mobo isn't MSI and I don't like Dragon Center, I'm just putting electric tape over the RGB strip. Either that or I'll use OpenRGB once its compatible with MSI parts.
Case reviewed well from what I can tell. Has good airflow, GPU fits, looks good, etc.
PSU is 850w to give myself some overhead for possible future overclocking.
Fans are just placeholders for now.
