Patriot Intros DDR4 Kits With Two Modules, Ups Highest Frequency To 3400 MHz
The timings are atrocious.
DDR4 with faster frequencies but much higher timings?
I don't think this is worth it.
Better to wait until the timings are improved.
Man we really need some new memory tech in the computing world.
DDR came out 15 years ago, and from then till now, latency hasnt gotten any better. Sure burst bandwidth has improved, but that only helps certain workloads.
Where is the 3200mhz cas 2 memory?
You two geniuses just don't understand how memory timings work. CL16 at 3400 is faster than CL8 at 1600; 9.4 nanoseconds vs. 10 nanoseconds. Getting CL2 at 3200 is ridiculous, that's 1.25 nanoseconds. That's the kind of latency you get from cache. The distance from the memory chips to the CPU in itself causes latency approximately on the order of a quarter to half a nanosecond.
Yes i understand how CAS works perfectly.
Whats wrong with wishing that in 15 years they would improve latency? Sure bandwidth improvements help certain workloads(for instance GPUs need lots), and dont matter at all for others. And ya you can get cherry picked memory down to about 8ns or so against the 10 that DDR had back then. So, ya thats faster, but not really that much faster.
I would realy like some faster memory... Whats wrong with wanting cas 2 ddr4 3200. Sure its completey impracticle with the DDR spec and silicon. But thats my point, we need a NEW memory technology that actually improves latency. Something that makes you go wow i want that....
Which is what the computing industry has been lacking for awhile now. 5% improvements a year are boreing! I want the old days back where technology doubled in power every year or so.
HBM perhaps? The same technology AMD uses on the Fury line of video cards. The memory and the CPU on the same interposer on a very wide bus. You will need to buy the CPU and the memory together, as they will come in the same package.
Memory that uses light pipes directly into the CPU is still prohibitively expensive and a long way off (and even then people will be complaining about the latency of light speed), but Hey, Just look how far we've come from 8-bit atari's working at 400Khz with memory clocking in at 250Kbps... be patient, we will get there, but you have to give moores law the most important element, time.
