Hi there.
For a while now I've had this issue where my computer boots, but I almost never get past the BIOS splash screen.
Here's a quick rundown of 2 ways it can go when I press the power button:
1.
The only way to get out of this No Signal is to forcefully shut down the PC via Power button.
2.
I have tried going into advanced options to "Continue" but that again gives me: BIOS splash -> No Signal.
Sometimes, randomly, it does work and I get into the login screen however shortly after I get No Signal.
Last time this happened it looked like this.
Things I have tried (Some unnecessary I know):
The weird thing about all this is that both before and after wiping my SSD, normal startup does not work, but I can boot into Windows in Safe Mode. I have no Idea what this tells me.
My PC:
I really have no other ideas on how I could possibly fix this other than just buy a whole new PC.
1.
- I press the power button
- My monitor shows the BIOS splash screen
- My monitor turns black amd says "No Signal"
2.
- It says "Preparing Automatic Repair"
- Then "Diagnosing PC"
- I get this blue screen
- If I click "Restart", it reatarts, shows BIOS splash screen. Then my monitor turns black amd says "No Signal"
- Different PSU
- New Motherboard
- Different GPU
- Different CPU Cooler
- Less/More RAM
- System Restore
- Uninstall Updates
- Reset PC (Delete Everything)
- Update BIOS
- Completely Wipe SSD and install Windows from USB
My PC:
- OS: Windows 10 Home
- Motherboard: MSI Z370-A Pro
- GPU: Gigabyte RTX 2070
- CPU: Intel I7 8700
- RAM: 16GB DDR4
- PSU: Corsair RM650X
